Command reference
network port broadcast-domain delete
Delete a layer 2 broadcast domain
Delete a broadcast domain that contains no ports.
-ipspace <IPspace> - IPspace Name
The IPspace to which the broadcast domain belongs
-broadcast-domain <Broadcast Domain> - Layer 2 Broadcast Domain
The name of the broadcast domain to be deleted.
The following example deletes the broadcast domain "mgmt" in IPspace "Default".
cluster1::network port broadcast-domain> delete -ipspace Default -broadcast-domain mgmt
