The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage array remove
PDF of this doc site
Creating your file...
Your file is ready
Remove a storage array record from the array profile database.
The storage array remove
command discards array profile records for a particular storage array from the cluster database. The command fails if a storage array is still connected to the cluster. Use the storage array config show command to view the array connectivity status. The array target port can be removed using the storage array port remove command.
-name <text>
- Name-
Name of the storage array you want to remove from the database.
cluster1::> storage array remove IBM_1722_1
