network options detect-switchless-cluster modify
Modify the status of switchless cluster detection
This command enables or disables the automatic detection of a switchless cluster. A switchless cluster consists of two nodes where the cluster ports are directly connected without a switch between them.
[-enabled {true|false}] - Enable Switchless Cluster Detection
This parameter specifies whether switchless cluster detection is enabled or not. Setting this parameter to true enables switchless cluster detection.
The following example enables switchless cluster detection:
        cluster1::*> network options detect-switchless-cluster modify -enabled true
