volume efficiency inactive-data-compression start
Start inactive data compression on a volume.
The volume efficiency inactive-data-compression start command is used to start inactive data compression on a volume.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the vserver of the volume.
-volume <volume name>- Volume Name (privilege: advanced)-
This specifies the volume on which inactive data compression should be started.
[-s, -inactive-days <integer>]- Compression Days Count (privilege: advanced)-
Data older than 'inactive-days' days is compressed.
[-m, -scan-mode {default|compute_compression_savings}]- scanner mode (privilege: advanced)-
This specifies in which mode inactive data compression scanner should be started. Two mode available 'default' and 'compute_compression_savings'. 'default' scanner will start compressing the cold data in volume. 'compute_compression_savings' scanner will calculate the auto adaptive compression savings on the volume.
The following example displays information for starting inactive data compression scan on volume "vol1":
cluster:::> volume efficiency inactive-data-compression start -vserver vs1 -volume vol1 Inactive data compression scan started on volume vol1 in Vserver vs1.
