vserver peer permission show
Display Vserver peer permissions
The vserver peer permission show command displays the following information about Vserver peer permissions:
Peer cluster name
Local Vserver name
Applications
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-peer-cluster <text>]- Peer Cluster Name
If this parameter is specified, the command displays permissions that have the specified peer cluster name.
- [-vserver <text>]- Vserver Name
If this parameter is specified, the command displays permissions that match the specified local Vserver.
- [-applications {snapmirror|flexcache}]- Peering Applications
If this parameter is specified, the command displays permissions that have the specified applications.
The following examples illustrate how to display Vserver peer permissions:
cluster1::> vserver peer permission show Peer Cluster Vserver Applications ---------------- --------------- ----------------- cluster2 "*" snapmirror cluster3 vs1 snapmirror 2 entries were displayed.
 PDFs
PDFs
