system node show-discovered
- PDF of this doc site
Creating your file...
Display all nodes discovered on the local network
The system node show-discovered
command displays information about all the detectable nodes on the local cluster network. This includes both nodes in a cluster and nodes that do not belong to a cluster. You can filter the output to show only nodes that do not belong to a cluster or nodes that are in a cluster.
To see a list of values that are in use for a particular field, use the -fields
parameter of this command with the list of field names you wish to view.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If the
-instance
parameter is specified, the command displays detailed information about each node. [-node <text>]
- Node Name-
This parameter specifies the name of a node for which information is to be displayed. If this parameter is not specified, the command displays information about all discovered nodes.
[-is-in-cluster {true|false}]
- Is in a Cluster-
If this parameter is set to
false
, the command lists only nodes that do not belong to a cluster. [-cluster-uuid <UUID>]
- Cluster UUID-
Displays information about nodes belonging to the cluster that has the UUID you specify.
[-cluster-name <text>]
- Cluster Name-
Displays information about nodes belonging to the cluster that has the name you specify.
[-serial-number <text>]
- Node Serial Number-
Displays information about the node that has the serial number you specify.
[-addresses <IP Address>,…]
- Cluster IP Addresses-
Displays information about the node that has the cluster IP addresses you specify.
[-netmask <IP Address>]
- Cluster Address Mask-
Displays information about the nodes that have the netmask address you specify.
[-nvramid <nvramid>]
- Node NVRAM ID-
Displays information about the node that has the NVRAM ID you specify.
[-partner-nvramid <nvramid>]
- Partner NVRAM ID-
Displays information about the node that has an HA partner with the NVRAM ID you specify.
[-model <text>]
- Model-
Displays the nodes that have the specified model number.
[-version <text>]
- Software Version-
Displays the nodes that have the specified version of Data ONTAP.
The following example displays information about all discovered nodes in the cluster network:
cluster1::*> system node show-discovered Node Cluster Addresses NVRAM ID Partner NVRAM ------------- ------------- --------------- ----------- -------------- 4069114-60-0 - 169.254.232.178 4069114600 - 4069114-60-2 - 169.254.79.38 4069114602 - 4069114-60-3 - 169.254.195.76 4069114603 - cluster1-01 cluster1 169.254.140.39 4069114628 4069114629 cluster1-02 cluster1 169.254.138.137 4069114629 4069114628
