ONTAP commands
vserver cifs security modify
Modify CIFS security settings
The vserver cifs security modify command modifies CIFS server security settings.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver whose CIFS security settings you want to modify.
[-kerberos-clock-skew <integer>] - Maximum Allowed Kerberos Clock Skew
This parameter specifies the maximum allowed Kerberos ticket clock skew in minutes. The default is 5 minutes.
[-kerberos-ticket-age <integer>] - Kerberos Ticket Lifetime
This parameter specifies the Kerberos ticket lifetime in hours. The default is 10 hours.
[-kerberos-renew-age <integer>] - Maximum Kerberos Ticket Renewal Days
This parameter specifies the maximum Kerberos ticket renewal lifetime in days. The default is 7 days.
[-kerberos-kdc-timeout <integer>] - Timeout for Kerberos KDC Connections (Secs)
This parameter specifies the timeout for sockets on KDCs after which all KDCs are marked as unreachable. The default is 3 seconds.
[-is-signing-required {true|false}] - Require Signing for Incoming CIFS Traffic
This parameter specifies whether signing is required for incoming CIFS traffic. The default is false .
[-is-password-complexity-required {true|false}] - Require Password Complexity for Local User Accounts
This parameter specifies whether password complexity is required for CIFS local users. If this parameter is set to true , password complexity is required. If the value is set to false , password complexity is not required. The default is true for CIFS servers.
[-use-start-tls-for-ad-ldap {true|false}] - Use start_tls for AD LDAP Connections
This parameter specifies whether to use Start TLS over AD LDAP connections. When enabled, the communication between the Data ONTAP LDAP Client and the LDAP Server will be encrypted using Start TLS. Start TLS is a mechanism to provide secure communication by using the TLS/SSL protocols. If you do not specify this parameter, the default is false .
[-is-aes-encryption-enabled {true|false}] - (DEPRECATED)-Is AES-128 and AES-256 Encryption for Kerberos Enabled
This parameter specifies whether to use Kerberos AES-128 and AES-256 encryption types for authentication. When enabled and depending on negotiation with the KDC service, it is possible for authentication operations to utilize these encryption types. If you do not specify this parameter, the default is false .
Note This parameter is deprecated and may be removed from a future release.
[-lm-compatibility-level {lm-ntlm-ntlmv2-krb|ntlm-ntlmv2-krb|ntlmv2-krb|krb}] - LM Compatibility Level
This parameter specifies the LM compatibility level. The default is lm-ntlm-ntlmv2-krb (LM, NTLM, NTLMv2 and Kerberos).
[-is-smb-encryption-required {true|false}] - Require SMB Encryption for Incoming CIFS Traffic
This parameter specifies whether SMB encryption is required when accessing shares in the Vserver. When enabled and depending on negotiation during session setup, it is possible that data transfers between the client and the server are made secure by encrypting the SMB traffic. If you do not specify this parameter, the default is false .
[-session-security-for-ad-ldap {none|sign|seal}] - Client Session Security
This parameter specifies the level of security to be used for LDAP communications. If you do not specify this parameter, the default is none .
LDAP Client Session Security can be one of the following:
  • none - No Signing or Sealing.
  • sign - Sign LDAP traffic.
  • seal - Seal and Sign LDAP traffic.
[-smb1-enabled-for-dc-connections {false|true|system-default}] - (DEPRECATED)-SMB1 Enabled for DC Connections
This parameter specifies whether SMB1 is enabled for use with connections to domain controllers. If you do not specify this parameter, the default is system-default .
SMB1 Enabled For DC Connections can be one of the following:
  • false - SMB1 is not enabled.
  • true - SMB1 is enabled.
  • system-default - This sets the option to whatever is the default for the release of Data ONTAP that is running. For this release it is: SMB1 is enabled.
Note This parameter is deprecated because the SMB1 protocol is obsolete and considered insecure. It might be removed in a future release.
[-smb2-enabled-for-dc-connections {false|true|system-default}] - SMB2 Enabled for DC Connections
This parameter specifies whether SMB2 is enabled for use with connections to domain controllers. If you do not specify this parameter, the default is system-default .
SMB2 Enabled For DC Connections can be one of the following:
  • false - SMB2 is not enabled.
  • true - SMB2 is enabled.
  • system-default - This sets the option to whatever is the default for the release of Data ONTAP that is running. For this release it is: SMB2 is enabled.
[-referral-enabled-for-ad-ldap {true|false}] - LDAP Referral Chasing Enabled For AD LDAP Connections
This parameter specifies whether LDAP referral is enabled for AD LDAP connections. If you do not specify this parameter, the default is false .
[-use-ldaps-for-ad-ldap {true|false}] - Use LDAPS for Secure Active Directory LDAP Connections
This parameter specifies whether to use LDAPS over AD LDAP connections. When enabled, the communication between the Data ONTAP LDAP Client and the LDAP Server will be encrypted using LDAPS and port 636 will be used. LDAPS is a mechanism to provide secure communication by using the TLS/SSL protocols and port 636. If you do not specify this parameter, the default is false .
[-encryption-required-for-dc-connections {true|false}] - Encryption is required for DC Connection
This parameter specifies whether encryption is required for use with connections to domain controllers. If you do not specify this parameter, the default is false .
Encryption required For DC Connections can be one of the following:
  • false - Encryption is not required.
  • true - Encryption is required.
[-aes-enabled-for-netlogon-channel {true|false}] - AES session key enabled for NetLogon channel
This parameter specifies whether AES session key will be negotiated as part of the NetLogon secure channel establishment. If you do not specify this parameter, the default is false .
[-try-channel-binding-for-ad-ldap {true|false}] - Try Channel Binding For AD LDAP Connections
This parameter specifies whether channel binding will be tried for AD LDAP connections. If you do not specify this parameter, the default is true . Channel binding will be tried only if -use-start-tls-for-ad-ldap or -use-ldaps-for-ad-ldap is enabled along with -session-security-for-ad-ldap set to either sign or seal .
[-advertised-enc-types <CIFS Kerberos Encryption Type>,…​] - Encryption Types Advertised to Kerberos
Encryption types advertised to Kerberos.The default setting is des ,` rc4` .
The following example makes the following changes: the Kerberos clock skew is set to 3 minutes, the Kerberos ticket lifetime to 8 hours and it makes signing required for Vserver "vs1".
cluster1::> vserver cifs security modify -vserver vs1 -kerberos-clock-skew 3 -kerberos-ticket-age 8 -is-signing-required true
cluster1::> vserver cifs security show
Vserver: vs1
Kerberos Clock Skew:               3 minutes
                                  Kerberos Ticket Age:               8 hours
                                 Kerberos Renewal Age:               7 days
                                 Kerberos KDC Timeout:               3 seconds
                                  Is Signing Required:            true
                      Is Password Complexity Required:            true
                 Use start_tls For AD LDAP connection:           false
                            Is AES Encryption Enabled:           false
                               LM Compatibility Level:             krb
                           Is SMB Encryption Required:           false
                              Client Session Security:            none
                      SMB1 Enabled For DC Connections:  system-default
                      SMB2 Enabled For DC Connections:  system-default
LDAP Referral Chasing Enabled For AD LDAP Connections:           false
                    Use LDAPS for AD LDAP Connections:            true
               Encryption required For DC Connections:           false
                     AES enabled for Netlogon channel:           false
          Try Channel Binding For AD LDAP Connections:            true
              Encryption Types Advertised to Kerberos:           des, rc4
