network options ipv6 modify
PDF of this doc site
Creating your file...
Your file is ready
Modify IPv6 options
This command sets the state of IPv6 options for the cluster.
[-enabled <true>]
- IPv6 Enabled-
Setting this parameter to
true
enables IPv6 for the cluster. IPv6 cannot be disabled once it is enabled for the cluster. Call technical support for guidance regarding disabling IPv6. [-is-ra-processing-enabled {true|false}]
- Router Advertisement (RA) Processing Enabled-
true
enables cluster to process IPv6 router advertisements. Setting it tofalse
disables router advertisement processing by the cluster.
The following example enables IPv6 for the cluster: cluster1::> network options ipv6 modify -enabled true The following example enables IPv6 Router Advertisement processing for the cluster: cluster1::> network options ipv6 modify -is-ra-processing-enabled true The following example disables IPv6 Router Advertisement processing for the cluster: cluster1::> network options ipv6 modify -is-ra-processing-enabled false
