ONTAP commands
network options ipv6 modify
Modify IPv6 options
This command sets the state of IPv6 options for the cluster.
[-enabled <true>] - IPv6 Enabled
Setting this parameter to true enables IPv6 for the cluster. IPv6 cannot be disabled once it is enabled for the cluster. Call technical support for guidance regarding disabling IPv6.
[-is-ra-processing-enabled {true|false}] - Router Advertisement (RA) Processing Enabled
Setting this parameter to true enables cluster to process IPv6 router advertisements. Setting it to false disables router advertisement processing by the cluster.
The following example enables IPv6 for the cluster:
    cluster1::> network options ipv6 modify -enabled true
The following example enables IPv6 Router Advertisement processing for the
cluster:
    cluster1::> network options ipv6 modify -is-ra-processing-enabled true
The following example disables IPv6 Router Advertisement processing for the
cluster:
    cluster1::> network options ipv6 modify -is-ra-processing-enabled false
