volume recovery-queue modify
Modify attributes of volumes in the recovery queue
The volume recovery-queue modify command modifies the retention period of a volume in the recovery queue.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name (privilege: advanced)-
This specifies the volume that is to be modified.
[-retention-hours <integer>]- Volume Delete Retention (privilege: advanced)-
This specifies the time in hours that the volume will be available in the recovery queue for recovery. For example, a value of "10" means that the volume will retained in the recovery queue at least 10 hours.
The following example modifies a volume named vol1_1234 on a Vserver named vs1 in the recovery queue.
cluster1::*> volume recovery-queue modify -vserver vs1 -volume vol1_1234 -retention-hours 10
