ONTAP 9.12.1 commands
network route delete
Delete a static route
The network route delete command deletes a static route from a Vserver.
-vserver <vserver> - Vserver Name
Use this parameter to specify the Vserver on which the route is to be deleted.
-destination <IP Address/Mask> - Destination/Mask
Use this parameter to specify the IP address and subnet mask of the route's destination. The format for this value is: address, slash ("/"), mask. For example, 0.0.0.0/0 is a correctly formatted value for the -destination parameter.
-gateway <IP Address> - Gateway
Use this parameter to specify the gateway on which the route is to be deleted.
The following example deletes a route within Vserver vs0 for destination 0.0.0.0/0.
cluster1::network route delete -vserver vs0 -destination 0.0.0.0/0
