ONTAP 9.12.1 commands
network route show
Display static routes
The network route show command displays a group of static routes within one or more Vservers. You can view routes within specified Vservers, routes with specified destinations, and routes with specified gateways.
{ [-fields <fieldname>,…​]
Use this parameter to display only certain fields of the routing tables.
| [-instance ] }
Use this parameter to display all fields of the routing tables.
[-vserver <vserver>] - Vserver Name
Use this parameter to display only routes that have the specified Vserver as their origin.
[-destination <IP Address/Mask>] - Destination/Mask
Use this parameter to display only routes that have the specified IP address and subnet mask as their destination. The format for this value is: address, slash ("/"), mask. The example below has 0.0.0.0/0 as a valid value for the -destination parameter.
[-gateway <IP Address>] - Gateway
Use this parameter to display only routes that have the specified IP address as their gateway.
[-metric <integer>] - Metric
Use this parameter to display only routes that have the specified metric.
[-ipspace <IPspace>] - IPspace Name
Use this parameter to optionally specify the IPspace associated with the Vserver. This parameter can be used in conjunction with the Vserver parameter in order to configure the same route across multiple Vservers within an IPspace.
[-address-family {ipv4|ipv6|ipv6z}] - Address family of the route
Use this parameter to display only the routes that have the specified address-family.
The following example displays information about all routing groups.
cluster1::> network route show
  (network route show)
Server              Destination     Gateway         Metric
node1
                    0.0.0.0/0       10.61.208.1     20
node2
vs0
3 entries were displayed.
