The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
application provisioning config show
PDF of this doc site
Creating your file...
Your file is ready
Display options for application provisioning
This command displays options for application provisioning.
cluster1::*> application provisioning config show Is Mixed Storage Services Allowed: false
