system node internal-switch dump stat
Display onboard switch port statistics counter
The system node internal-switch dump stat command is used to display the counter information of the internal switch ports.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Use this parameter to specify the node the switch resides on.
[-switch-id <integer>]- Switch-
Use this parameter to specify the switch id. For example, 1.
[-port-id <integer>]- Port-
Use this parameter to specify the port id. For example, 0.
[-stat-id <text>]- Counter Name-
Use this parameter to specify the counter name.
[-valued <integer>]- Counter Value-
Use this parameter to show the value of specified counter.
[-port-name <text>]- Port Name-
Use this parameter to specify the port name. For example, e0M.
The following example shows partial counter information of the internal switch 0 on Node1
cluster1::> system node internal-switch dump stat -node Node1 -switch-id 0 Port Port Name Counter Value ---- ---------------- ------------------- --------- Node: Node1 , Switch: 0 0 sw-wrench 1024ToMaxOctets 22480201 0 sw-wrench 128To255Octets 119552 0 sw-wrench 256To511Octets 345587 0 sw-wrench 512To1023Octets 1250437 0 sw-wrench 64Octets 803025
