ONTAP commands
system node internal-switch dump stat
Display onboard switch port statistics counter
The system node internal-switch dump stat command is used to display the counter information of the internal switch ports.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node
Use this parameter to specify the node the switch resides on.
[-switch-id <integer>] - Switch
Use this parameter to specify the switch id. For example, 1.
[-port-id <integer>] - Port
Use this parameter to specify the port id. For example, 0.
[-stat-id <text>] - Counter Name
Use this parameter to specify the counter name.
[-valued <integer>] - Counter Value
Use this parameter to show the value of specified counter.
[-port-name <text>] - Port Name
Use this parameter to specify the port name. For example, e0M.
The following example shows partial counter information of the internal switch 0 on Node1
cluster1::> system node internal-switch dump stat -node Node1 -switch-id 0
Port  Port Name          Counter               Value
Node: Node1        , Switch: 0
0     sw-wrench          1024ToMaxOctets       22480201
0     sw-wrench          128To255Octets        119552
0     sw-wrench          256To511Octets        345587
0     sw-wrench          512To1023Octets       1250437
0     sw-wrench          64Octets              803025
