The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume file privileged-delete
PDF of this doc site
Creating your file...
Your file is ready
Perform a privileged-delete operation on unexpired WORM files on a SnapLock enterprise volume
The ` volume file privileged-delete ` command is used to perform a privileged-delete operation on unexpired WORM files on a SnapLock enterprise volume. The only built-in role that has access to the command is "vsadmin-snaplock"
-vserver <vserver name>
- Vserver-
Specifies the Vserver which hosts the SnapLock enterprise volume.
-file </vol/<volume name>/<file path>>
- File Path-
Specifies the absolute path of the file to be deleted. The value begins with /vol/<volumename>.
The following example deletes the unexpired WORM file "/vol/vol1/wormfile"
. The file wormfile is stored in volume vol1 under Vserver vserver1
vserver1::> volume file privileged-delete -file /vol/vol1/wormfile [Job 76] Job succeeded: Privileged-delete of File "vs1:/vol/sle_vol1/wormfile" Completed.
