ONTAP commands
cluster agent connection show
Display agent connections
This command displays the connections that have been established to help external managers manage the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-name <text>] - Name (privilege: advanced)
Selects the connections that match the supplied name.
[-uuid <UUID>] - UUID (privilege: advanced)
Selects the connections that match the supplied uuid.
[-destination <text>] - Destination URL (privilege: advanced)
Selects the connections that match the supplied desination.
[-state {connecting|connected|error|disabled|partial}] - State (privilege: advanced)
Selects the connections that match the supplied state. The state can have one of the following values:
  • connecting - The agent is in the process of establishing the connection.
  • connected - The connection is up and active.
  • error - The connection is down due to a problem. See error-message and error-time for details.
  • disabled - The connection has been administratively disabled.
[-use-proxy {true|false}] - Use Proxy (privilege: advanced)
Establish this connection through an HTTP Proxy server associated with this connection's IPspace
[-subscribe-address <text>] - Subscribe Address (privilege: advanced)
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>] - Publish Address (privilege: advanced)
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>] - Auth Certificate UUID (privilege: advanced)
Selects the connections that match the supplied certificate-uuid.
[-certificate-name <text>] - Auth Certificate Name (privilege: advanced)
Selects the connections that match the supplied certificate-name
[-csr-url <text>] - Auth CSR URL (privilege: advanced)
URL to send certicate signing request (CSR) that will be used for authenticating with the destination.
[-manager-token <text>] - Manager Token (privilege: advanced)
Selects the connections that match the supplied manager-token.
[-ipspace <IPspace>] - IPspace for connection (privilege: advanced)
The IPspace to use for the connection
[-error-code <integer>] - Last Error Code (privilege: advanced)
Selects the connections that match the supplied error-code.
[-error-message <text>] - Last Error Message (privilege: advanced)
Selects the connections that match the supplied error-message.
[-error-time <MM/DD/YYYY HH:MM:SS>] - Last Error Time (privilege: advanced)
Selects the connections that match the supplied error-time.
[-node <nodename>] - Node owning the connection (privilege: advanced)
The node owning the connection
[-msg-recv-total <integer>] - Total messages received from manager (privilege: advanced)
[-msg-recv-manifest <integer>] - Total manifest messages received from manager (privilege: advanced)
[-msg-recv-baseline-request <integer>] - Total baseline.request messages received from manager (privilege: advanced)
[-msg-recv-counters-request <integer>] - Total counters.request messages received from manager (privilege: advanced)
[-msg-recv-connection-status <integer>] - Total connection status messages received from manager (privilege: advanced)
[-msg-recv-connection-modify <integer>] - Total connection modify messages received from manager (privilege: advanced)
[-msg-recv-unknown <integer>] - Total unknown messages received from manager (privilege: advanced)
[-msg-send-total <integer>] - Total messages sent to manager (privilege: advanced)
[-msg-send-manifest-request <integer>] - Total manifest.request messages sent to manager (privilege: advanced)
[-msg-send-baseline <integer>] - Total baseline messages sent to manager (privilege: advanced)
[-msg-send-counters <integer>] - Total counters messages sent to manager (privilege: advanced)
[-msg-send-connection-status <integer>] - Total connection status messages sent to manager (privilege: advanced)
[-msg-send-errors <integer>] - Total error messages sent to manager (privilege: advanced)
[-msg-delivery-errors <integer>] - Total errors encountered attempting to send/receive (privilege: advanced)
[-msg-connection-total <integer>] - Total connection attempts (privilege: advanced)
[-msg-connection-errors <integer>] - Total connection errors (privilege: advanced)
[-msg-transport-errors <integer>] - Total transport errors (privilege: advanced)
[-application <text>] - Client Application (privilege: advanced)
Selects the connections that match the supplied application.
[-application-url <text>] - App URL (privilege: advanced)
Selects the connections that match the supplied application-url.
[-idle-timeout <integer>] - Idle Timeout (privilege: advanced)
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout
[-address-family {unknown|ipv4|ipv6}] - Address Family (privilege: advanced)
Specify address family.
[-auto-delete-error-minutes <integer>] - Auto-delete when disconnected for specified minutes (privilege: advanced)
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection show
Name          Destination                   State      Application    Use Proxy
cloudinsights amqpws://172.31.50.251        connected  Cloud Insights false
