cluster agent connection show
Display Cloud Agent connections
This command displays the connections that have been established to help external managers manage the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-name <text>]- Name (privilege: advanced)-
Selects the connections that match the supplied name.
[-uuid <UUID>]- UUID (privilege: advanced)-
Selects the connections that match the supplied UUID.
[-destination <text>]- Destination URL (privilege: advanced)-
Selects the connections that match the supplied destination.
[-state {connecting|connected|error|disabled|partial|static}]- State (privilege: advanced)-
Selects the connections that match the supplied state. The state can have one of the following values:
connecting - The agent is in the process of establishing the connection.
connected - The connection is up and active.
error - The connection is down due to a problem. See error-message and error-time for details.
disabled - The connection has been administratively disabled.
partial - The connection has been partially established and is not ready to deliver messages.
static - The agent is of static instance type and does not require an external connection.
[-use-proxy {true|false}]- Use Proxy (privilege: advanced)-
Establish this connection through an HTTP proxy server associated with this connection's IPspace
[-subscribe-address <text>]- Subscribe Address (privilege: advanced)-
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>]- Publish Address (privilege: advanced)-
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>]- Authentication Certificate UUID (privilege: advanced)-
Selects the connections that match the supplied certificate UUID.
[-csr-url <text>]- Authentication CSR URL (privilege: advanced)-
URL to send certicate signing request (CSR) that will be used for authenticating with the destination.
[-manager-token <text>]- Manager Token (privilege: advanced)-
Selects the connections that match the supplied manager token.
[-ipspace <IPspace>]- IPspace for Connection (privilege: advanced)-
The IPspace to use for the connection
[-error-code <integer>]- Last Error Code (privilege: advanced)-
Selects the connections that match the supplied error code.
[-error-message <text>]- Last Error Message (privilege: advanced)-
Selects the connections that match the supplied error message.
[-error-time <MM/DD/YYYY HH:MM:SS>]- Last Error Time (privilege: advanced)-
Selects the connections that match the supplied error time.
[-node <nodename>]- Node Owning the Connection (privilege: advanced)-
The node owning the connection
[-msg-recv-total <integer>]- Total Messages Received from Manager (privilege: advanced)-
Total messages received from manager
[-msg-recv-manifest <integer>]- Total Manifest Messages Received from Manager (privilege: advanced)-
Total manifest messages received from manager
[-msg-recv-baseline-request <integer>]- Total baseline.request Messages Received from Manager (privilege: advanced)-
Total baseline.request messages received from manager
[-msg-recv-counters-request <integer>]- Total counters.request Messages Received from Manager (privilege: advanced)-
Total counters.request messages received from manager
[-msg-recv-connection-status <integer>]- Total Connection Status Messages Received from Manager (privilege: advanced)-
Total connection status messages received from manager
[-msg-recv-connection-modify <integer>]- Total Connection Modify Messages Received from Manager (privilege: advanced)-
Total connection modify messages received from manager
[-msg-recv-agent-status <integer>]- Total agent.status.request Messages Received from Manager (privilege: advanced)-
Total agent.status.request Messages received from Manager
[-msg-recv-subscription-create <integer>]- Total Subscription Create Messages Received from Manager (privilege: advanced)-
Total subscription create messages received from manager
[-msg-recv-subscription-delete <integer>]- Total Subscription Delete Messages Received from Manager (privilege: advanced)-
Total subscription delete messages received from manager
[-msg-recv-unknown <integer>]- Total Unknown Messages Received from Manager (privilege: advanced)-
Total unknown messages received from manager
[-msg-send-total <integer>]- Total Messages Sent to Manager (privilege: advanced)-
Total messages sent to manager
[-msg-send-manifest-request <integer>]- Total manifest.request Messages Sent to Manager (privilege: advanced)-
Total manifest.request messages sent to manager
[-msg-send-baseline <integer>]- Total Baseline Messages Sent to Manager (privilege: advanced)-
Total baseline messages sent to manager
[-msg-send-counters <integer>]- Total Counters Messages Sent to Manager (privilege: advanced)-
Total counters messages sent to manager
[-msg-send-connection-status <integer>]- Total Connection Status Messages Sent to Manager (privilege: advanced)-
Total connection status messages sent to manager
[-msg-send-subscription-status <integer>]- Total Subscription Status Messages Sent to Manager (privilege: advanced)-
Total subscription status messages received from manager
[-msg-send-errors <integer>]- Total Error Messages Sent to Manager (privilege: advanced)-
Total error messages sent to manager
[-msg-delivery-errors <integer>]- Total Errors Encountered Attempting to Send/receive (privilege: advanced)-
Total errors encountered attempting to send/receive
[-msg-send-topicrelay <integer>]- Total ONTAP PubSub Topic Messages Sent to Manager (privilege: advanced)-
Total ONTAP PubSub Topic messages sent to manager
[-msg-send-agent-status-details <integer>]- Total agent.status Messages Sent to Manager (privilege: advanced)-
Total agent.status Messages sent to Manager
[-msg-connection-total <integer>]- Total Connection Attempts (privilege: advanced)-
Total connection attempts
[-msg-connection-errors <integer>]- Total Connection Errors (privilege: advanced)-
Total connection errors
[-msg-transport-errors <integer>]- Total Transport Errors (privilege: advanced)-
Total transport errors
[-application <text>]- Client Application (privilege: advanced)-
Selects the connections that match the supplied application.
[-application-url <text>]- Application URL (privilege: advanced)-
Selects the connections that match the supplied application URL.
[-idle-timeout <integer>]- Idle Timeout (in seconds) (privilege: advanced)-
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout.
[-address-family {unknown|ipv4|ipv6}]- Address Family (privilege: advanced)-
Specify address family.
[-auto-delete-error-minutes {<integer>|-}]- Time to Auto-delete when disconnected (in minutes) (privilege: advanced)-
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection show Name Destination State Application Use Proxy ------------- ----------------------------- ---------- -------------- --------- cloudinsights amqpws://172.31.50.251 connected Cloud Insights false
