cluster agent connection show
Display agent connections
This command displays the connections that have been established to help external managers manage the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-name <text>]
- Name-
Selects the connections that match the supplied name.
[-uuid <UUID>]
- UUID-
Selects the connections that match the supplied uuid.
[-destination <text>]
- Destination URL-
Selects the connections that match the supplied desination.
[-state {connecting|connected|error|disabled|partial}]
- State-
Selects the connections that match the supplied state. The state can have one of the following values:
connecting - The agent is in the process of establishing the connection.
connected - The connection is up and active.
error - The connection is down due to a problem. See error-message and error-time for details.
disabled - The connection has been administratively disabled.
[-use-proxy {true|false}]
- Use Proxy-
Establish this connection through an HTTP Proxy server associated with this connection’s IPspace
[-subscribe-address <text>]
- Subscribe Address-
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>]
- Publish Address-
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>]
- Auth Certificate UUID-
Selects the connections that match the supplied certificate-uuid.
[-certificate-name <text>]
- Auth Certificate Name-
Selects the connections that match the supplied certificate-name
[-csr-url <text>]
- Auth CSR URL-
URL to send certicate signing request (CSR) that will be used for authenticating with the destination.
[-manager-token <text>]
- Manager Token-
Selects the connections that match the supplied manager-token.
[-ipspace <IPspace>]
- IPspace for connection-
The IPspace to use for the connection
[-error-code <integer>]
- Last Error Code-
Selects the connections that match the supplied error-code.
[-error-message <text>]
- Last Error Message-
Selects the connections that match the supplied error-message.
[-error-time <MM/DD/YYYY HH:MM:SS>]
- Last Error Time-
Selects the connections that match the supplied error-time.
[-node <nodename>]
- Node owning the connection-
The node owning the connection
[-msg-recv-total <integer>]
- Total messages received from manager-
[-msg-recv-manifest <integer>]
- Total manifest messages received from manager-
[-msg-recv-baseline-request <integer>]
- Total baseline.request messages received from manager-
[-msg-recv-counters-request <integer>]
- Total counters.request messages received from manager-
[-msg-recv-connection-status <integer>]
- Total connection status messages received from manager-
[-msg-recv-connection-modify <integer>]
- Total connection modify messages received from manager-
[-msg-recv-unknown <integer>]
- Total unknown messages received from manager-
[-msg-send-total <integer>]
- Total messages sent to manager-
[-msg-send-manifest-request <integer>]
- Total manifest.request messages sent to manager-
[-msg-send-baseline <integer>]
- Total baseline messages sent to manager-
[-msg-send-counters <integer>]
- Total counters messages sent to manager-
[-msg-send-connection-status <integer>]
- Total connection status messages sent to manager-
[-msg-send-errors <integer>]
- Total error messages sent to manager-
[-msg-delivery-errors <integer>]
- Total errors encountered attempting to send/receive-
[-msg-connection-total <integer>]
- Total connection attempts-
[-msg-connection-errors <integer>]
- Total connection errors-
[-msg-transport-errors <integer>]
- Total transport errors-
[-application <text>]
- Client Application-
Selects the connections that match the supplied application.
[-application-url <text>]
- App URL-
Selects the connections that match the supplied application-url.
[-idle-timeout <integer>]
- Idle Timeout-
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout
[-address-family {unknown|ipv4|ipv6}]
- Address Family-
Specify address family.
[-auto-delete-error-minutes <integer>]
- Auto-delete when disconnected for specified minutes-
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection show Name Destination State Application Use Proxy ------------- ----------------------------- ---------- -------------- --------- cloudinsights amqpws://172.31.50.251 connected Cloud Insights false
