      job watch-progress
Watch the progress of a job
The job watch-progress command displays the progress of a job, and periodically updates that display. You can specify the frequency of the updates.
- -id <integer>- Job ID
Use this parameter to specify the numeric ID of the job to monitor.
- [-vserver <vserver name>]- Owning Vserver
Use this parameter to specify the name of the Vserver that owns the job.
- [-interval <integer>]- Refresh Interval (seconds)
Use this parameter to specify the number of seconds between updates.
The following example show how to monitor the progress of the job that has ID 222 on Vserver vs0 . The progress display updates every 3 seconds.
cluster1::> job watch-progress -vserver vs0 -id 222 -interval 3
 PDFs
PDFs
