job watch-progress
Watch the progress of a job
The job watch-progress
command displays the progress of a job, and periodically updates that display. You can specify the frequency of the updates.
-id <integer>
- Job ID-
Use this parameter to specify the numeric ID of the job to monitor.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter to specify the name of the Vserver that owns the job.
[-interval <integer>]
- Refresh Interval (seconds)-
Use this parameter to specify the number of seconds between updates.
The following example show how to monitor the progress of the job that has ID 222
on Vserver vs0
. The progress display updates every 3 seconds.
cluster1::> job watch-progress -vserver vs0 -id 222 -interval 3
