vserver fcp wwpn-alias show
Displays a list of the WWPN aliases configured for initiators
This command displays aliases associated with World Wide Port Names (WWPN).
You can also use these commands to display WWPN aliases: |
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display a list of WWPNs and the associated aliases that match the Vserver name that you specify.
[-a, -alias <text>]
- Initiator WWPN Alias-
Use this parameter to display the WWPN that matches the alias that you specify.
[-w, -wwpn <FC WWN>]
- Initiator WWPN-
Use this parameter to display a list of aliases that match the WWPN that you specify.
cluster1::> vserver fcp wwpn-alias show Initiator Initiator Vserver WWPN Alias --------- ----------------------- ------------------ vs1 2f:a0:00:a0:98:0b:56:13 my_alias
Displays the alias my_alias for the WWPN 2f:a0:00:a0:98:0b:56:13 on Vserver vs1.
