vserver fcp wwpn-alias show
Displays a list of the WWPN aliases configured for initiators
This command displays aliases associated with World Wide Port Names (WWPN).
|  | You can also use these commands to display WWPN aliases: |
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display a list of WWPNs and the associated aliases that match the Vserver name that you specify.
- [-a, -alias <text>]- Initiator WWPN Alias
Use this parameter to display the WWPN that matches the alias that you specify.
- [-w, -wwpn <FC WWN>]- Initiator WWPN
Use this parameter to display a list of aliases that match the WWPN that you specify.
cluster1::> vserver fcp wwpn-alias show
    Initiator               Initiator
Vserver   WWPN                    Alias
vs1       2f:a0:00:a0:98:0b:56:13 my_alias
Displays the alias my_alias for the WWPN 2f:a0:00:a0:98:0b:56:13 on Vserver vs1.
 PDFs
PDFs
