ONTAP commands
vserver fcp wwpn-alias show
Displays a list of the WWPN aliases configured for initiators
This command displays aliases associated with World Wide Port Names (WWPN).
Note You can also use these commands to display WWPN aliases:
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display a list of WWPNs and the associated aliases that match the Vserver name that you specify.
[-a, -alias <text>] - Initiator WWPN Alias
Use this parameter to display the WWPN that matches the alias that you specify.
[-w, -wwpn <FC WWN>] - Initiator WWPN
Use this parameter to display a list of aliases that match the WWPN that you specify.
cluster1::> vserver fcp wwpn-alias show
    Initiator               Initiator
Vserver   WWPN                    Alias
vs1       2f:a0:00:a0:98:0b:56:13 my_alias
Displays the alias my_alias for the WWPN 2f:a0:00:a0:98:0b:56:13 on Vserver vs1.
