lun igroup remove
Remove initiators from an initiator group
This command removes an initiator from an initiator group. You can only remove an initiator if no existing LUN maps are defined for that initiator group. You must unmap the LUNs from the initiator group with the lun unmap command before you can remove initiators from the initiator group.
You can use the force option to remove an initiator and associated LUN maps.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-igroup <text> - Igroup Name
Specifies the initiator group from which to remove an initiator.
[-initiator <text>,…​] - Initiators
Specifies the initiator name to remove. Use the WWPN, IQN or the alias of the initiator.
[-f, -force <true>] - Force
Forcibly removes an initiator and any associated LUN maps.
[-child-igroups <text>,…​] - Child Igroups
Specifies the child initiator groups to remove.
cluster1::> lun igroup remove -vserver vs1 -igroup ig1 -initiator iqn.1992-08.com.mv.mvinitiator
Removes the initiator iqn.1992-08.com.mv.mvinitiator from Vserver vs1 and initiator group ig1.
