ONTAP commands
vserver cifs cache sid-to-name show
Display sid-to-name cache entries
The vserver cifs cache sid-to-name show command displays the Windows user information cached by security identifier (SID).
{ [-fields <fieldname>,…​]
| [-instance ] }
Use this parameter to display detailed information about the Windows user entries cached by the security identifier (SID).
[-vserver <vserver name>] - Vserver (privilege: advanced)
Use this parameter to specify the Vserver for which the Windows user entries that are cached by the security identifier (SID) need to be displayed.
[-sid <text>] - SID (privilege: advanced)
Use this parameter to display information only about the cached Windows user entries that have the specified security identifier (SID).
[-win-name <text>] - Windows Name (privilege: advanced)
Use this parameter to specify the Windows name for which the cached entries need to be displayed.
[-sid-type <integer>] - SID type (privilege: advanced)
Use this parameter to display information only about the cached Windows user entries that have the specified security identifier (SID) type.
[-sid-mode <integer>] - SID mode (privilege: advanced)
Use this parameter to display information only about the cached Windows user entries that have the specified security identifier (SID) mode.
[-flags <integer>] - Flags (privilege: advanced)
Use this parameter to display information only about the Windows user entries cached by the security identifier (SID) that have the specified flags.
[-domain-name <text>] - Domain Name (privilege: advanced)
Use this parameter to display information only about the Windows user entries cached by the security identifier (SID) that have the specified domain name.
[-create-time <MM/DD/YYYY HH:MM:SS>] - Create Time (privilege: advanced)
Use this parameter to display information only about the Windows user entries that were cached at the specified time.
[-source {none|files|dns|nis|ldap|netgrp_byname|dc}] - Source of the Entry (privilege: advanced)
Use this parameter to display information only about the Windows user entries cached by the security identifier (SID) that have the specified lookup source.
The following example shows how to display all of the Windows users which are cached by the security identifier (SID):
cluster1::> vserver cifs cache sid-to-name show
The following example shows how to display all of the Windows user entries cached by the security identifier (SID) for Vserver vs0:
cluster1::> vserver cifs cache sid-to-name show -vserver vs0
