metrocluster configuration-settings dr-group delete
Delete a DR group in a MetroCluster over IP setup
The metrocluster configuration-settings dr-group delete
command deletes a DR group and its node partnerships that were configured using the metrocluster configuration-settings dr-group create command.
This command cannot be run if the metrocluster configuration-settings interface create command has configured a network logical interface on a network port provisioned for MetroCluster. The metrocluster configuration-settings interface delete command must then be run to delete the network logical interfaces on every node in the DR group.
commands are run in the following order to remove the MetroCluster over IP configuration:
-dr-group-id <integer>
- Dr group Id-
This parameter indentifies the DR group to be deleted.
The following example shows the deletion of the MetroCluster DR group:
clusA::> metrocluster configuration-settings dr-group delete -dr-group-id 1 Warning: This command deletes the existing DR group relationship. Are you sure you want to proceed ? {y|n}: y [Job 279] Job succeeded: DR Group Delete is successful. clusA::> metrocluster configuration-settings dr-group show No DR groups exist. clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 ready for DR group create A2 ready for DR group create clusB B1 ready for DR group create B2 ready for DR group create 4 entries were displayed.
