metrocluster configuration-settings dr-group delete
Delete a DR group in a MetroCluster over IP setup
The metrocluster configuration-settings dr-group delete command deletes a DR group and its node partnerships that were configured using the metrocluster configuration-settings dr-group create command.
This command cannot be run if the metrocluster configuration-settings interface create command has configured a network logical interface on a network port provisioned for MetroCluster. The metrocluster configuration-settings interface delete command must then be run to delete the network logical interfaces on every node in the DR group.
The metrocluster configuration-settings commands are run in the following order to remove the MetroCluster over IP configuration:
metrocluster configuration-settings dr-group delete.
- -dr-group-id <integer>- Dr group Id
This parameter indentifies the DR group to be deleted.
The following example shows the deletion of the MetroCluster DR group:
clusA::> metrocluster configuration-settings dr-group delete -dr-group-id 1
Warning: This command deletes the existing DR group relationship. Are you sure
         you want to proceed ? {y|n}: y
[Job 279] Job succeeded: DR Group Delete is successful.
clusA::>  metrocluster configuration-settings dr-group  show
No DR groups exist.
clusA::> metrocluster configuration-settings show-status
Cluster                    Node               Configuration Settings Status
clusA
                           A1                 ready for DR group create
                           A2                 ready for DR group create
clusB
                           B1                 ready for DR group create
                           B2                 ready for DR group create
4 entries were displayed.
 PDFs
PDFs
