metrocluster check aggregate show
Show results of MetroCluster check for aggregates
The metrocluster check aggregate show
command displays the results of aggregate checks performed by the metrocluster check run command.
The command verifies the following aspects of the configuration of all aggregates in MetroCluster:
mirroring-status: This check verifies that the aggregate is mirrored.
disk-pool-allocation: This check verifies that the disks belonging to this aggregate have been correctly allocated to the right pools.
Additional information about the warnings (if any) and recovery steps can be viewed by running the command with the -instance option.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <Node name>]
- Node Name-
This is the name of the node for which the check was run. If this parameter is specified, only rows with this node will be displayed.
[-aggregate <aggregate name>]
- Name of the Aggregate-
This is the name of the aggregate for which the check was run. If this parameter is specified, only rows with this aggregate will be displayed.
[-check <MetroCluster Aggregate Check>]
- Type of Check-
This is the type of the check performed. If this parameter is specified, only rows with this check will be displayed.
[-cluster <Cluster name>]
- Name of Cluster-
This is the name of the cluster the node belongs to. If this parameter is specified, only rows with this cluster will be displayed.
[-result {ok|warning|not-run|not-applicable}]
- Result of the Check-
This is the result of the check. If this parameter is specified, only rows with this result will be displayed.
[-additional-info <text>,…]
- Additional Information/Recovery Steps-
This is additional information about the check. This field has more information and recovery steps for the warning. If this parameter is specified, only rows with this additional info will be displayed.
The following example shows the execution of the command in a MetroCluster configuration with two nodes per cluster:
clusA::> metrocluster check aggregate show Last Checked On: 4/9/2014 20:11:46 Node Aggregate Check Result --------------------- --------------------- --------------------- --------- clusA-01 a1_required_data_aggr mirroring-status ok disk-pool-allocation ok aggr0_a1 mirroring-status ok disk-pool-allocation ok clusA-02 a2_required_data_aggr mirroring-status ok disk-pool-allocation ok aggr0_a2 mirroring-status ok disk-pool-allocation ok clusB-01 b1_required_data_aggr mirroring-status ok disk-pool-allocation ok aggr0_b1 mirroring-status ok disk-pool-allocation ok clusB-02 aggr0_b2 mirroring-status ok disk-pool-allocation ok b2_required_data_aggr mirroring-status ok disk-pool-allocation ok 16 entries were displayed.
The following example shows the execution of the command with -instance option:
clusA::> metrocluster check aggregate show -instance Node Name: clusA-01 Name of the Aggregate: a1_required_data_aggr_1 Type of Check: mirroring-status Name of Cluster: clusA Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusA-01 Name of the Aggregate: a1_required_data_aggr_1 Type of Check: disk-pool-allocation Name of Cluster: clusA Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusA-01 Name of the Aggregate: a1_required_data_aggr_2 Type of Check: mirroring-status Name of Cluster: clusA Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusA-01 Name of the Aggregate: a1_required_data_aggr_2 Type of Check: disk-pool-allocation Name of Cluster: clusA Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusA-01 Name of the Aggregate: aggr0_a1 Type of Check: mirroring-status Name of Cluster: clusA Result of the Check: warning Additional Information/Recovery Steps: Root aggregate "aggr0_a1" is un-mirrored. Root aggregates should be mirrored in a MetroCluster configuration. Node Name: clusA-01 Name of the Aggregate: aggr0_a1 Type of Check: disk-pool-allocation Name of Cluster: clusA Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: aggr0_b1 Type of Check: mirroring-status Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: aggr0_b1 Type of Check: disk-pool-allocation Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: b1_required_data_aggr_1 Type of Check: mirroring-status Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: b1_required_data_aggr_1 Type of Check: disk-pool-allocation Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: b1_required_data_aggr_2 Type of Check: mirroring-status Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - Node Name: clusB-01 Name of the Aggregate: b1_required_data_aggr_2 Type of Check: disk-pool-allocation Name of Cluster: clusB Result of the Check: ok Additional Information/Recovery Steps: - 12 entries were displayed.
