system bridge remove
Remove a bridge from monitoring
The system bridge remove enables you to remove FC-to-SAS bridges that were previously added for SNMP monitoring.
-name <text> - Bridge Name
This parameter specifies the name of the bridge added for monitoring.
The following command removes 'ATTO_10.226.197.16' bridge from monitoring:
cluster1::> system bridge remove -name ATTO_10.226.197.16
cluster1::> system bridge show
        Is        Monitor
    Bridge     Symbolic Name Vendor  Model     Bridge WWN       Monitored Status
    ATTO_FibreBridge6500N_1
               Bridge Number 16
                             Atto    FibreBridge 6500N
                                               2000001086603824 false     -
    ATTO_FibreBridge6500N_2
               Not Set       Atto    FibreBridge 6500N
                                               20000010866037e8 false     -
    ATTO_FibreBridge6500N_3
                                               2000001086609e0e false     -
    ATTO_FibreBridge6500N_4
                                               2000001086609c06 false     -
    4 entries were displayed.
