system bridge remove
Remove a bridge from monitoring
The system bridge remove
enables you to remove FC-to-SAS bridges that were previously added for SNMP monitoring.
-name <text>
- Bridge Name-
This parameter specifies the name of the bridge added for monitoring.
The following command removes 'ATTO_10.226.197.16' bridge from monitoring:
cluster1::> system bridge remove -name ATTO_10.226.197.16 cluster1::> system bridge show Is Monitor Bridge Symbolic Name Vendor Model Bridge WWN Monitored Status ---------- ------------- ------- --------- ---------------- --------- ------- ATTO_FibreBridge6500N_1 Bridge Number 16 Atto FibreBridge 6500N 2000001086603824 false - ATTO_FibreBridge6500N_2 Not Set Atto FibreBridge 6500N 20000010866037e8 false - ATTO_FibreBridge6500N_3 Not Set Atto FibreBridge 6500N 2000001086609e0e false - ATTO_FibreBridge6500N_4 Not Set Atto FibreBridge 6500N 2000001086609c06 false - 4 entries were displayed.
