metrocluster check config-replication show
Display MetroCluster config-replication status information
The metrocluster check config-replication show command displays the results of MetroCluster configuration replication.
The command verifies the following aspects of MetroCluster configuration replication :
  • Enabled: Verifies that MetroCluster configuration replication is enabled on the cluster.
  • Running: Verifies that MetroCluster configuration replication is running on the cluster.
  • Remote Heartbeat: Verifies that the MetroCluster configuration replication heartbeat with the remote cluster is healthy.
  • Last Heartbeat Sent: Prints the timestamp of the last MetroCluster configuration replication heartbeat sent to the remote cluster.
  • Last Heartbeat Received: Prints the timestamp of the last MetroCluster configuration replication hearbeat received from the remote cluster.
  • Storage Status: Verifies that MetroCluster configuration replication storage is healthy.
  • Storage In Use: Prints the location of MetroCluster configuration replication storage.
  • Storage Remarks: Prints the underlying root cause for non healthy MetroCluster configuration storage.
  • Vserver Streams: Verifies that MetroCluster configuration replication Vserver streams are healthy.
  • Cluster Streams: Verifies that MetroCluster configuration replication Cluster streams are healthy.
Additional information about the warnings (if any) and recovery steps can be viewed by running the command with the -instance option.
[-instance ]
The following example shows the output of metrocluster check config-replication show :
clusA::metrocluster check config-replication> show
                       Enabled: true
                       Running: true
              Remote Heartbeat: ok
           Last Heartbeat Sent: 12/12/2013 14:24:59
       Last Heartbeat Received: 12/12/2013 14:25:00
                Storage Status: ok
                Storage In Use: Cluster-wide Volume: MDV_CRS_1bc7134a5ddf11e3b63f123478563412_A
               Storage Remarks: -
               Vserver Streams: ok
               Cluster Streams: ok
