cluster ring show
Display cluster node member's replication rings
The cluster ring show command displays a cluster's ring-replication status. Support personnel might ask you to run this command to assist with troubleshooting.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Selects the rings that match this parameter value.
- [-unitname {mgmt|vldb|vifmgr|bcomd|crs|availd}]- Unit Name (privilege: advanced)
Selects the rings that match this parameter value. Possible values are: -
mgmt- The management application
vldb- The volume location database
vifmgr- The virtual-interface manager
bcomd- The SAN management daemon
crs- The configuration replication service
- [-online {master|secondary|offline}]- Status (privilege: advanced)
- [-epoch <integer>]- Epoch (privilege: advanced)
- [-master <nodename>]- Master Node (privilege: advanced)
- [-local <nodename>]- Local Node (privilege: advanced)
- [-db-epoch <integer>]- DB Epoch (privilege: advanced)
- [-db-trnxs <integer>]- DB Transaction (privilege: advanced)
- [-num-online <integer>]- Number Online (privilege: advanced)
- [-rdb-uuid <UUID>]- RDB UUID (privilege: advanced)
The following example displays information about all replication rings in a two-node cluster:
cluster1::*> cluster ring show Node UnitName Epoch DB Epoch DB Trnxs Master Online --------- -------- -------- -------- -------- --------- --------- node0 mgmt 1 1 1068 node0 master node0 vldb 1 1 98 node0 master node0 vifmgr 1 1 350 node0 master node0 bcomd 1 1 56 node0 master node0 crs 1 1 88 node0 master node1 mgmt 1 1 1068 node0 secondary node1 vldb 1 1 98 node0 secondary node1 vifmgr 1 1 350 node0 secondary node1 bcomd 1 1 56 node0 secondary node1 crs 1 1 88 node0 secondary 10 entries were displayed.
 PDFs
PDFs
