cluster ring show
Display cluster node member's replication rings
The cluster ring show
command displays a cluster's ring-replication status. Support personnel might ask you to run this command to assist with troubleshooting.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the rings that match this parameter value.
[-unitname {mgmt|vldb|vifmgr|bcomd|crs|availd}]
- Unit Name (privilege: advanced)-
Selects the rings that match this parameter value. Possible values are:
mgmt
- The management application -
vldb
- The volume location database -
vifmgr
- The virtual-interface manager -
bcomd
- The SAN management daemon -
crs
- The configuration replication service
[-online {master|secondary|offline}]
- Status (privilege: advanced)-
[-epoch <integer>]
- Epoch (privilege: advanced)-
[-master <nodename>]
- Master Node (privilege: advanced)-
[-local <nodename>]
- Local Node (privilege: advanced)-
[-db-epoch <integer>]
- DB Epoch (privilege: advanced)-
[-db-trnxs <integer>]
- DB Transaction (privilege: advanced)-
[-num-online <integer>]
- Number Online (privilege: advanced)-
[-rdb-uuid <UUID>]
- RDB UUID (privilege: advanced)-
The following example displays information about all replication rings in a two-node cluster:
cluster1::*> cluster ring show Node UnitName Epoch DB Epoch DB Trnxs Master Online --------- -------- -------- -------- -------- --------- --------- node0 mgmt 1 1 1068 node0 master node0 vldb 1 1 98 node0 master node0 vifmgr 1 1 350 node0 master node0 bcomd 1 1 56 node0 master node0 crs 1 1 88 node0 master node1 mgmt 1 1 1068 node0 secondary node1 vldb 1 1 98 node0 secondary node1 vifmgr 1 1 350 node0 secondary node1 bcomd 1 1 56 node0 secondary node1 crs 1 1 88 node0 secondary 10 entries were displayed.
