lun transition start
Start LUN Transition Processing
The lun transition start
command starts LUN transition for the specified volume. Normally, transition is started automatically when snapmirror break is issued for the volume, this command allows restarting in the event automatic transitioning was interrupted or failed.
-vserver <Vserver Name>
- Vserver Name-
The name of the Vserver containing the volume. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
The name of the volume to restart LUN transition.
The following example starts LUN transition on a volume named volume1
in a Vserver named vs1
cluster1::*> lun transition start -vserver vs1 -volume volume1
