ONTAP commands
vserver iscsi command show
Display active iSCSI commands
This command displays the status of active iSCSI commands in an iSCSI session. If you specify an iSCSI command ID, the command shows what commands are active in a session and is useful for initiator debugging.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to display a list of active iSCSI commands that match the Vserver name that you specify.
[-tpgroup <text>] - Target Portal Group
Use this parameter to display a list of active iSCSI commands that are within the target portal group.
[-tsih <integer>] - Target Session ID
Use this parameter to display a list of active iSCSI commands that match the target session ID handle that you specify.
[-command-id <integer>] - Command ID
Use this parameter to display a list of active iSCSI commands that match the command ID that you specify.
[-initiator-name <text>] - Initiator Name
Use this parameter to display a list of active iSCSI commands that match the initiator name that you specify.
[-initiator-alias <text>] - Initiator Alias
Use this parameter to display a list of active iSCSI commands that match the initiator alias that you specify.
[-isid <text>] - Initiator Session ID
Use this parameter to display a list of active iSCSI commands that match the initiator session ID that you specify.
[-command-sub-id <integer>] - Command Sub ID
Use this parameter to display a list of active iSCSI commands that match the command sub ID that you specify.
[-command-state <iSCSI Command States>] - Command State
Use this parameter to display a list of active iSCSI commands that match the command state that you specify.
[-command-type {Sequenced|Imm_Taskmgmt|Imm_Other}] - Command Type
If you use this parameter, the command displays a list of active iSCSI commands that contains the specified command type. The command types indicate:
  • "Sequenced" — the system processes the commands in sequence
  • "Imm_Taskmgmt" — the system processes the commands immediately
  • "Imm_Other" — the system processes the commands as queued
cluster1::> vserver iscsi command show -instance -vserver vs_1
server: vs_1
        Target Portal Group Name: tpgroup_1
               Target Session ID: 2
                      Command ID: 20797
                  Initiator Name: iqn.1993-08.org.debian:01:fa752b8a5a3a
                 Initiator Alias: alias_1
            Initiator Session ID: 00:02:3d:01:00:00
                  Command Sub ID: 20797
                   Command State: Scsicdb_Waiting_STLayer
                    Command Type: Sequenced
Displays detailed information for active iSCSI commands in Vserver vs_1.
