volume flexcache origin config modify
Modify FlexCache Origin Configuration
The volume flexcache origin config modify command modifies volume specific options of an origin of a FlexCache volume.
-origin-vserver <Vserver Name> - Vserver Name
This specifies the Vserver in which the origin of a FlexCache volume is located.
-origin-volume <volume name> - Origin Volume Name
This specifies the origin of a FlexCache volume.
[-is-bli-enabled {true|false}] - Is BLI Enabled
This parameter specifies whether data invalidation at block level is enabled or not. By default, -is-bli-enabled is false .
[-is-global-file-locking-enabled {true|false}] - Is Global File Locking Enabled
This parameter specifies the global file locking mode for the volume. By default, -is-global-file-locking-enabled is false . When global file locking mode is enabled for the volume, the "is_disconnected_mode_off_for_locks" flag is always set to true .
The following example modifies the is-bli-enabled field value to true:
cluster1::> flexcache origin config modify -origin-volume origin_flexgroup -origin-vserver vs3_c2 -is-bli-enabled true
        (volume flexcache origin config show)
cluster1::> flexcache origin config show -origin-volume origin_flexgroup -origin-vserver vs3_c2
Vserver: vs3_c2
                      Origin Volume Name: origin_flexgroup
                          Is BLI Enabled: true
