cluster image package get
Fetch a package file from a URL into the cluster image package repository
The cluster image package get
command fetches a Data ONTAP package file specified by the URL into the cluster. The package is stored in the cluster package respository and the information from the package is stored in the update database.
-url <text>
- Package URL-
Specifies the URL from which to get the package.
The following example displays how to get a package from a URL:
cluster1::> cluster image package get -url http://example.com/image.tgz
