vserver export-policy delete
Delete a rule set
The vserver export-policy delete
command deletes an export policy. You cannot delete the default policy (named default
) for a Vserver unless you delete the Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the export policy that you want to delete is located.
-policyname <export policy name>
- Policy Name-
This parameter specifies the export policy that you want to delete.
The following example deletes an export policy named test_expolicy from a Vserver named vs0:
vs1::> vserver export-policy delete -vserver vs0 -policyname test_expolicy
