volume file clone split load modify
Modify maximum split load on a node
The volume file clone split load modify command can be used to change the maximum split load (file, LUN or NVMe namespace clones) of a node.
-node {<nodename>|local} - Node Name
Node name on which the new maximum split load is being applied.
[-max-split-load {<integer>[KB|MB|GB|TB|PB]}] - Maximum Clone Split Load
This specifies the new maximum split load of a node. This is the amount of clone create load, the node can take at any point of time. If it crosses this limit, then the clone create requests will not be allowed, till the split load is less than maximum split load
The following example changes the new maximum limit to 10TB on node1.
cluster1::*> volume file clone split load*> modify -node clone-01 -max-split-load 100KB
