snaplock compliance-clock show
Displays the node ComplianceClock
The ` snaplock compliance-clock show ` command will display System ComplianeClock of the nodes in the cluster. It will display the following information:
Node name
ComplianceClock Time
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified, the command will display ComplianceClock for that particular node only.
[-time <text>]- ComplianceClock Time of the Node-
If this parameter is specified, the command will display nodes having the same
-timevalue.
cluster1::> snaplock compliance-clock show
Node ComplianceClock Time
node1 Mon Jan 12 11:34:15 IST 2015 +05:30
node2 Mon Jan 12 11:34:10 IST 2015 +05:30
2 entries were displayed.
cluster1::> snaplock compliance-clock show -node node1
node1 Mon Jan 12 11:34:45 IST 2015 +05:30
