Command reference
snaplock compliance-clock show
Displays the node ComplianceClock
The ` snaplock compliance-clock show ` command will display System ComplianeClock of the nodes in the cluster. It will display the following information:
  • Node name
  • ComplianceClock Time
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, the command will display ComplianceClock for that particular node only.
[-time <text>] - ComplianceClock Time of the Node
If this parameter is specified, the command will display nodes having the same -time value.
cluster1::> snaplock compliance-clock show
        Node                ComplianceClock Time
        node1               Mon Jan 12 11:34:15 IST 2015 +05:30
        node2               Mon Jan 12 11:34:10 IST 2015 +05:30
        2 entries were displayed.
cluster1::> snaplock compliance-clock show -node node1
        node1               Mon Jan 12 11:34:45 IST 2015 +05:30
