security ipsec policy delete
Delete an IPsec policy
This command deletes an existing IPsec policy.
- -vserver <vserver name>- Vserver
Specifies the Vserver to which the policy belongs. If there is only a single Vserver capable of supporting IPsec, the Vserver parameter is implied.
- -name <text>- Policy Name
This required parameter specifies the name of the policy to be deleted. The name may be a text string (1-64 bytes), a hexadecimal string (begining with '0x') or a base64 encoded binary string (beginning with '0s').
This is an example of IPsec policy deletion where two or more Vservers are capable of supporting IPsec:
cluster-1::> security ipsec policy delete -vserver vs_data1 -name DiscardTraffic
This is an example of IPsec policy deletion where only a single Vserver is capable of supporting IPsec:
cluster-1::> security ipsec policy delete -name policy1
This is an example of an attempt to delete a non-existent IPsec policy:
cluster-1::> security ipsec policy delete -vserver vs_data1 -name Discard Error: There are no entries matching your query.
 PDFs
PDFs
