ONTAP commands
cluster peer policy show
Display the policy configuration for the cluster peering service
The cluster peer policy show command displays the prevailing cluster peer authentication policy. There are two policies at present: one to control whether any cluster peer relationships can be unauthenticated, and one to control the minimum length for a passphrase. If the policy is set to preclude unauthenticated peering relationships, then unauthenticated relationships cannot be created inadvertently. Passphrases of less than the minimum length may not be used. By default, this minimum length is set to 8, so passphrases must be 8 characters long or longer.
This example shows the cluster peer policy when unauthenticated relationships may not be created inadvertently.
cluster1::> cluster peer policy show
Is Unauthenticated Cluster Peer Communication Permitted:  false
                        Minimum Length for a Passphrase:  9
    Is Unencrypted Cluster Peer Communication Permitted: true
