ONTAP 9.11.1 commands
system node coredump segment delete-all
Delete all core segments on a node
This command deletes all the core segments on a node.
-node {<nodename>|local} - Node
This specifies the node on which to delete the core segments.
This deletes all the core segments for node1 .
cluster1::> system node coredump segment delete-all -node node1
