      system node coredump segment delete-all
Delete all core segments on a node
This command deletes all the core segments on a node.
- -node {<nodename>|local}- Node
This specifies the node on which to delete the core segments.
This deletes all the core segments for node1 .
cluster1::> system node coredump segment delete-all -node node1
 PDFs
PDFs
