system node coredump segment delete-all
Delete all core segments on a node
This command deletes all the core segments on a node.
-node {<nodename>|local}
- Node-
This specifies the node on which to delete the core segments.
This deletes all the core segments for node1
cluster1::> system node coredump segment delete-all -node node1
