ONTAP commands
volume encryption conversion start
Start a volume encryption conversion operation
The volume encryption conversion start command converts a non-encrypted volume to encrypted volume.
-vserver <vserver name> - Vserver Name
This parameter specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This parameter specifies the name of the volume being encrypted.
[-ignore-warning {true|false}] - Ignore Warning for Conversion Start
If this parameter is set, the command ignores the confirmation message.
Looking for answers?
Try Doc, our Gen AI Assistant.
