volume encryption conversion start
Start a volume encryption conversion operation
The volume encryption conversion start
command converts a non-encrypted volume to encrypted volume.
-vserver <vserver name>
- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This parameter specifies the name of the volume being encrypted.
[-ignore-warning {true|false}]
- Ignore Warning for Conversion Start-
If this parameter is set, the command ignores the confirmation message.
