vserver migrate resume
Resume a migrate operation
This command resumes a Vserver migrate operation. It must be run on the destination cluster of the Vserver migrate operation. The migrate operation, which either previously failed or was paused in order to prioritize other cluster operations, can be resumed.
- -vserver <vserver name>- Vserver Name
Name of the Vserver being migrated.
- [-auto-cutover {true|false}]- Automatically cutover when ready
This parameter specifies if the Vserver migrate operation should cutover automatically when ready. The default setting is true.
- [-auto-source-cleanup {true|false}]- Automatically cleanup the source vserver after cutover
This parameter specifies if the Vserver migrate operation should cleanup the source Vserver automatically. Setting the parameter requires diagnostic privilege. The default setting is true.
cluster1::> vserver migrate resume -vserver test -auto-cutover false
 PDFs
PDFs
